if i create a new a project than is it necessary that the standard folders in iso enviorment variable "std & "und" are empty and if they are empty( contain no file ) than how should i paste some suitable file in them so that i can extract the isometrics in basic format
thanks
by satender
projectiso std
this folder you have to place your customised file.
how pdms identify the option file
Previewisostd.txt is default for Iso Extraction from Design
PDMS looks for them in %PDMSUSER%/STD then in %ABCISO%/STD and if nothing found there it user file from %PDMSDFLTS%/STD
If File Exist in pdmsuser, file in project folder doesnot work
if in lapped joint flange face connection is raised flange and pipe connection is screwed than i should give bolt refrence or not please tell
thanks
by satender
