[FONT=Times New Roman][COLOR=#000000]Kind[/COLOR][/FONT] PDMS Specialists,
I have the following;
I want to change the attribute of an vertical column in a existing steelwork. For example from DIN-SPEC/HE220B to DIN-SPEC/HE200BW, can this be don through a multiple selection? And change all the attributes of the vertical columns in one single turn? Or do I need to change each attribute of an particular vertical column separately.
Depends on your model and the hierarchy... In Add-tab of list-window there are options like CE MEMBERS, if you have them all for example in one SBFR. Add identified might be good also if you like clicking. You can add sections with certain attributes like spec or cutl with Add selection. Isn't there anyone in your company who knows pdms and could help you with this? It is a bit hard to guess here what your 3d-model contains...
