this all exist in different areas of GUI. Why do you think other way?
There are so many different things which user wants to put on quick access. And every user has its own view. So there is could not be one simple solution
And thanks to PDMS we can manage it to add everything we want, in any combination that we want, to make our life easier.
To improve efficiency you need first to analyze what is the most often action user does and how much time he spend on it. And if this is as in your example switching on/off obstruction then you can make it more efficient putting it on quick access.
The other problem here that if you want to put everything on quick access then at the end you get millions of buttons and efficiency will decrease. So make analyze first
[QUOTE=c.ramesh;87239]Initially Obstruction Volume show with model. When user want to hide Obstruction Volume in the Screen, then
Users have to do 5 steps. 1. Settings 2. Graphics…
In Graphics Settings Window have to select 3. Representation tap
Then in Obstruction option have to select 4. Off
Next click 5.OK So it takes some time.
After put icon
[LIST] Easy to pick and One step One time pick for Obstruction On, next pick for Obstruction Off.
[/LIST]
View also we have to right click and select axis, very painful for my fingers.
reduce Mouse pick will reduce pain for my finger.
By the way if you don't want obstruction on system start you can manage it via some defaults file from pdmsdflts folder
[QUOTE=RUAV;87185]this all exist in different areas of GUI. Why do you think other way?
After put icon
[/LIST]
