Hello,
i am fighting with the expressions in autonaming.
I need to add at the end of the name, the insulation spec as follow:
25-P-1001-ABC-10000-W
where /W is the Ispec. So comes the " - " + namn of Ispec
And when we have no Ispec on the pipe, simply:
25-P-1001-ABC-10000
Here the expression that works without the Ispec condition:
!!ce.bore.real().value() & '-' & !!ce.fluref.namn & '-' & (namn of owner of owner) & !!ce.pspe.namn & '-' !!ce.Number
I want to add something like:
Ift(namn of Ispec EQ 'Unset' , ' ' , ('-' + namn of Ispec )
But it doesn't works....How can i test if Ispec is set or unset? Any suggestion?
Strange is that as Text for labellin it works....as Naming expression not....
Hi , thanks for help.
Unfortunately it doesn't work:
If i have a spec, it works fine.
If i don't have any spec, it seems the formula take care of + namn of ispe and as there is no name, i receive an error and the rule is not accepted.
I wrote 2 rules then:
One with Pipe without Insulation, giving criteria to the selection: unset(ISPEC)
-> !!CE.Bore.real().value().string() & '-' & !!CE.Fluref.namn & '-' & !!CE.Scsysf[1].namn & '-' & !!CE.pspe.namn & '-' & !!CE.Number
--> 25-P-1001-ABC-10000
One with Pipe with insulation, giving criteria to the selection : unset(ISPEC) EQ FALSE
->!!CE.Bore.real().value().string() & '-' & !!CE.Fluref.namn & '-' & !!CE.Scsysf[1].namn & '-' & !!CE.pspe.namn & '-' & !!CE.Number & '-' & !!CE.ispe.namn
-->25-P-1001-ABC-10000-W
That works......
Still strange, if i use the complete formula for labelling, it works fine...
