Misc AVEVA software
Misc AVEVA software
AVEVA Diagrams Pipe and branches attributes
  • Replies 5 replies
  • Views 75 views
Carlos martinez
Carlos martinez over 4 years ago
  • Carlos martinez
    Hi, i have the following question:
    If I create a pipe and fill in the attributes of d sign and operaci?n temperature and pressure conditions: Does these conditions are inherited automatically when I create a new branch or a new component (valve, in-line instrument,etc)?? Thanks
  • Atish naresh parkar
    Atish naresh parkar over 4 years ago
    Yes, for Branch,  If you create a Pipe with temprature and pressure set same values will be inherited for all the branch under it when you create any new branch.
    This is not applicable for component as they dont have Pressure and Temperature attributes.
    it only works for Pipe and Branch
  • Carlos martinez
    Thanks Athis for your answer. So i understand that if i want to generate a valve list where design conditions are shown, i need to export design conditions of the branch where the valve is located. Do you agree? Thanks
  • Parag S Newe
    Parag S Newe over 4 years ago
    Yea Carlsomzfz,
    You have to report Branch (OWNER of Component) attribute for this
    Q Temp of Owner
    OR
    Q Temp of Bran
  • Carlos martinez
    Thanks Prag
