line naming in diagrams
 I am trying to set up rules for AVEVA DIAGRAM PIPELINES Can you please guide me the possible way out .
6800-1111-40-1DS01-EW-WW -NI
Where 6800 - FIXED
            1111- LINE NUMBER
                40 - BORE SIZE
              1DS01 - PIPE SPEC
                    EW- TRACING SPEC
                    WW- FLUID REFRENCE
                     NI- INSULATION SPEC
can you please guide me on the path forward for the same
  • Assuming you've filled below Attributes/UDAs:
    1111- LINE NUMBER : (Number)
    40 - BORE SIZE:  (Bore)
    1DS01 - PIPE SPEC:  (PSPEC)
     EW- TRACING SPEC: (:Tracing)
     WW- FLUID REFRENCE: (:Fluid)
    NI- INSULATION SPEC: (ISPEC)
    You should use:
    '6800-' &  !!CE.Number & '-' & !!ce.bore.string().replace('mm','').real() & '-' & !!CE.PSPEC.NAMN & "-" & !!CE.:Tracing &'-' & !!CE.:Fluid & '-' & !!CE.ISPEC.NAMN
