Misc AVEVA software
AVEVA Engineering
dump attribut
3 subscribers
dump attribut
adak
over 8 years ago
adak
over 8 years ago
hi everybody
when you dump the attributs form the model 3d, you got only the design's attributs. how to get also the attributs from engineering linking to a pipe for example?
the aim is : to have all attributs when you export to RVM and open it in Navisworks.
thanks in advance
(sorry if not clear)
Ilgiz Kalimullin
over 8 years ago
1) create user defined attributes for design elements.
2) create rules for "Compare & Update" tool
3) run Compare & update between engineering database and design database
4) run export to RVM with dump attributes
adak
over 8 years ago
thanks kubik
but the aim is to have only attributs in engineering.
I thought that we can dump the attributs with something like :xxxx of englink (xxxx=nameof uda)
thanks for idea
Ilgiz Kalimullin
over 8 years ago
If you have programmer with PML skills, then you can write a simple macro for dump certain attributes.
