Misc AVEVA software
AVEVA Engineering
Engineering tag Reports
3 subscribers
Albie
over 7 years ago
Albie
over 7 years ago
Good day, I would like to know if there is a way to show tags that's been logically deleted as strikethrough on the report or exclude them completely from the equipment report.
I'm using engineering-tags 14.2.04
gilbert karel
over 7 years ago
Yes you can you will need to set up styles in the report designer with a rule.
The rule should be based on the logical delete Boolean called EXCEL.
RAJENDHAR RAMENDLA
over 7 years ago
Hi All,
Could you please help me in below error while loading line list in aveva engineering (tags) asap it is little bit very urgent.
An error occurred while matching file contents to database elements : Can't determine where in the database the element ENGITE should be created
Thanks
Rajendhar[/U]
