Misc AVEVA software
Misc AVEVA software
AVEVA Engineering Compare and update weight
  • Replies 5 replies
  • Subscribers 3 subscribers
  • Views 51 views
Silvana Dvornik
Silvana Dvornik over 5 years ago
  • Silvana Dvornik
    Dear,
    I have set dryweight component in engineering, but using compare/update to insert it on equipment UsrWeight it said that format is incorect. I managed to insert it into Uwmtxt but i don't know how to use this attribute.
    Please help.
  • Travis Fincaryk
    Travis Fincaryk over 5 years ago
    Ha I was just running into this problem last week. Ended up making a text attribute for the model. I'll look into the Uwntxt when I get a chance. Glade to know I'm not the only one trying this!
  • gilbert karel
    gilbert karel over 5 years ago
    It has been a while since I have done it and I don't have access to the project anymore but from memory I did it with advance configuration settings
    As the user weigh is set with brackets
    From memory I used in the advance settings Format('( {0} )', :weight of source)
  • gilbert karel
    Sorry wrong information not sure if this can be done try to some more investigating.
  • Ivica Rajčić
    Ivica Rajčić over 5 years ago
    Hi, I work with Silvana, we already tried Format('( {0} )', :Dryweight  of source) but it's no use. As we saw in help, attribute usrweight is  integer(500). We don't know what this  (500) means, but we tried to  insert only number in configuration settings and it also didn't do  anything. As I read in some pages on internet attribute Usrewight is  only for USER to enter, and system cannot insert anything in that field.  But we don't know why is then offered in COMPARE/UPDATE for inserting.
