Revisioning in P&ID (12.1.SP3)
  • Good Day All,
    Hopefully, someone here has had experience with listing revisions in the drawings. Apparently, SP3 has that capability. I have noticed a lot of enhancements and updates to the system, but I still haven't found how to list the revisions in the drawing. According to the documents, it is possible.
    Anyone have any ideas? I have already looked at the revision triangles, but we are wanting t mine the data from Document Manager.
    Thank you!
  • Good Day All,
    We found out how to add the revisions. They are located in the "Add Designators" command in the "Manage" tab. To place them, you can select one of the four options; "TABLE_REVISION_MAJOR_ASC","TABLE_REVISION_MAJOR_DESC", "TABLE_REVISION_MINOR_ASC","TABLE_REVISION_MINOR_DESC". This will list all of the variables available to you when you ISSUE a drawing.
    Warning:
    There is only one label type for this so you can only have one size and justification.
    The table builds down, so a negative value in the "Distance between rows:" must be used if you want the table to build up.
    Regards,
    Rod
