Good day. Can anyone teach me how to integrate Aveva P&ID with Aveva E3D?
First method is by working with ISO 15926 XML files.
There is a possible second method by directly linking AVEVA P&ID to AVEVA E3D by using the Compare and Update Utility.
However, I only read it from an AVEVA brochure and I have not tried it at work.
Edit: Sorry I mistyped ISO 15926 as ISO 15826 before.
Thank you very much for sharing these ideas. this is very helpful.
I want to share a problem i encountered on Aveva P&ID. The User Defined Attributes are not reflected on the P&ID report, even though the P&IDs are already synchronized and consolidated.
do you have ideas how to troubleshoot this problem?
thank you.
Have you tried doing "Clear Raw Database" and "Clear Database" in P&ID Reports?
