AVEVA Everything3D Using E3D on TTY mode
  • Replies 14 replies
  • Subscribers 17 subscribers
  • Views 645 views
Rodrigo Basniak
Rodrigo Basniak over 6 years ago
    I have tried with AVEVA Everything3D Design Mk2.1.0.16[Z21016-14]  (WINDOWS-NT 6.3)  (26 May 2018 : 00:19)
    At the beginning it seems it has crashed but then it enters DESIGN with no problems
  • Rodrigo Basniak
    Hi,
    When using PDMS in TTY mode, I would access it in TTY and then I could change modules using commands line ADMIN, DESIGN, MONITOR, etc.
    Now in E3D I cannot do this. If I open E3D in TTY and try to go to the Design module, using the DESIGN command, I get the following error:
    (39, 35) Cannot invoke Unset module when using Monitor
    How do I change modules via commands in E3D?
    Thanks in advance....
  • Venkata Rao Peta
    @echo off
    CALL "C:\Program Files (x86)\AVEVA\Administration1.5.0\mon.exe" PROD ADMIN init "C:\Program Files (x86)\AVEVA\Administration1.5.0\admin.init" TTY ProjAPS SYSTEM/XXXXXX /ALL $M/D:\Adminconcept\Expunge.mac
    usually E3D it will work in this way.
    Sorry if i understood the question in a wrong way
    No it is not possible.
    Paragon is now part of Aveva Catalogue
    Lexicon is part of Aveva Admin
    Different products.
    Same license.
  • Karthikeyan Soundara Pandiyan
    Karthikeyan Soundara Pandiyan over 6 years ago
    how to enter into PARAGON or LEXICON module from Design or Draw module, is that possible with E3D
  • Ahmad Fauzan
    Ahmad Fauzan over 5 years ago
    I accidentally running using shortcut file and works :encouragement:
    c:\temp\launch.lnk tty APS SYSTEM/XXXXXX /MDB $M/c:\temp\macro.mac
  • ZAPPELLA
    ZAPPELLA over 4 years ago
    [COLOR=#333333]CALL "C:\Program Files (x86)\AVEVA\Administration1.5.0\mon.exe" PROD [/COLOR][COLOR=#417394]ADMIN[/COLOR][COLOR=#333333] init "C:\Program Files (x86)\AVEVA\Administration1.5.0\admin.init" TTY ProjAPS SYSTEM/XXXXXX [/COLOR][COLOR=#ff0000]/ALL[/COLOR][COLOR=#333333] $M/D:\Adminconcept\Expunge.mac
    Wich syntax if i want enter in admin without MDB ?
    Thank you[/COLOR]
  • Jing Luo
    Jing Luo over 4 years ago
    ADD a line before DESIGN, and type DEV GRA in your mac file, use the bat file as same with PDMS.
  • mEhul Patel
    mEhul Patel over 1 year ago in reply to Venkata Rao Peta
    In my project password is not given in design module, then what I should place?
  • Emmanuel Desiderio
    Emmanuel Desiderio over 1 year ago in reply to mEhul Patel
    Your user account inside AVEVA E3D actually still have a password, although you are no longer required to input it in order to access AVEVA E3D normally, because your Windows user account is detected by AVEVA E3D as a valid user in the project. This is called AD (Active Directory) authentication for newer AVEVA E3D versions. For older AVEVA versions, I think it is called NT User Authentication.
    Please contact your Project Administrator or the person who has access to the AVEVA Administration program.
    He should know how passwords are set to each user in an AVEVA E3D project in your company.
    He should be also able to reset your password to a new one.
