Hello All,
How to use the expression in catalogue for the MDS supports to get the corresponding steel thickness from DESIGN between the u-bolts,
Thanks
Alfred
Hello All,
Thanks
Alfred
What is the hierarchy structure of the u-bolt? Is it a FIXING under the GENSEC that it's penetrating through?
In the new Support Application (no MDS) that's an ANCI element
Hi Anh Le,
This is Support ancillary. Below image FYR,
I need to frame an expression in the ancillary dataset to get the thickness of the angle thickness to align the nuts in the U-Bolt.
Let's say that the L thickness is Parameter Number 6, then you could try something like:
para6 of first mem of first mem of pcpset num1 of suppo
Hi Mr. Corrado,
Below error while giving the expression,
No error message for me. I have set String as Data Type:
I tried modifying the expression. But it's not working in Design,
Hi Alfred,
One question about the attached image. Out of the box the SSREFE elements are hidden, how do you got to show them? Any customization?
Thanks
Hi Natalia,
Type $T8+ in command window.
Thanks Venkatesan, it works fine!
