i am working on project with a large part of imported model.( no other choice to add them in 3d drawlist to work around)
Users have regular crash ,and i am able to reproduce them.
During my test which is : add element in 3dview and playing with te aveva clip volume
I constat that the ram used by AVEVA increase each time that i modify the clip volume and never back down even if i stop manipulation for 20min
.(eg when you play with other function ,you see a jump of ram but back to normal after that)
Due to this phenomene of cumul ,i cross the famous limit of 2GB of 32bytes application and then e3d crash.
There is any reason to increase ram for each clip box modification (and keep in memory the previous dimension)
Is there a tips to clean ram during execution of E3D or any configuration for this topics
Thank you
