(2,754) Argument 1 to ATTRIBUTE is unset
Hello,
I m trying to put a support and this error occurs
I'm sharing also the info from the command window
Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 1 of NGMSET /E3D/Snipes-NGMS -
Catalogue parameter number ( 1 ) out of range
OPAR parameter number ( 5 ) out of range
Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 2 of NGMSET /E3D/Snipes-NGMS -
In line 60 of PML function mdssctn.MDSSCTN
!this.gtyp = !sctn.catref.gtyp
Called from line 54 of PML function mdssupportsctns
!mdssctnobject = object MDSSCTN(!sctn)
Called from line 1302 of PML function mdscreateftzerothree.CREATEFT03
!!mdssupportsctns(!form)
Called from line 39 of PML function mdscreateft
!success = !createFt.createFt03(!method)
Called from line 91 of PML function mdscheckft03con
if (!!mdsCreateFt('FT03', !method).not()) then
Called from line 417 of PML function mdsinitialiseft
!frameworkCreated = !!mdsCheck$!<type>con(!creationMethod)
Called from line 1020 of PML function mdssupporteditor.INITIALISE
!!mdsInitialiseFT(!softType, !support)
Called from line 683 of PML function mdscreateancillary
!!mdsSupportEditor.initialise('CREATE', !softType, !selectedRest)
Called from line 42 of PML function kactioncommands
$!array[$!i]
Called from line 461 of PML function mdsancill.APPLY
!!kActionCommands(!!mdsAncill.action)
Called from line 1 of Command/Form Callback Command
!this.apply()
any Ideas?
Thanks in advance!
