Hello,
I m trying to put a support and this error occurs
(2,754) Argument 1 to ATTRIBUTE is unset
Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 1 of NGMSET /E3D/Snipes-NGMS - Catalogue parameter number ( 1 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 1 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 1 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 2 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 2 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 1 of NGMSET /E3D/Snipes-NGMS - Catalogue parameter number ( 1 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 1 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 1 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 2 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 2 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 1 of NGMSET /E3D/Snipes-NGMS - Catalogue parameter number ( 1 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 1 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 1 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 2 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range Catalogue error for component FIXING /PS02026/STRU-V1/Snipe-Start , catalogue primitive NLPYRAMID 2 of NGMSET /E3D/Snipes-NGMS - OPAR parameter number ( 5 ) out of range (2,754) Argument 1 to ATTRIBUTE is unset In line 60 of PML function mdssctn.MDSSCTN !this.gtyp = !sctn.catref.gtyp Called from line 54 of PML function mdssupportsctns !mdssctnobject = object MDSSCTN(!sctn) Called from line 1302 of PML function mdscreateftzerothree.CREATEFT03 !!mdssupportsctns(!form) Called from line 39 of PML function mdscreateft !success = !createFt.createFt03(!method) Called from line 91 of PML function mdscheckft03con if (!!mdsCreateFt('FT03', !method).not()) then Called from line 417 of PML function mdsinitialiseft !frameworkCreated = !!mdsCheck$!<type>con(!creationMethod) Called from line 1020 of PML function mdssupporteditor.INITIALISE !!mdsInitialiseFT(!softType, !support) Called from line 683 of PML function mdscreateancillary !!mdsSupportEditor.initialise('CREATE', !softType, !selectedRest) Called from line 42 of PML function kactioncommands $!array[$!i] Called from line 461 of PML function mdsancill.APPLY !!kActionCommands(!!mdsAncill.action) Called from line 1 of Command/Form Callback Command !this.apply()
I'm sharing also the info from the command window
any Ideas?
Thanks in advance!
