• [url=http://52.178.132.139/member.php?u=18468]vdhsoft[/url] has reported a post.
    Reason:
    Thank you!
    Post: [url=http://52.178.132.139/showthread.php?t=13473&p=75258#post75258]Error[/url]
    Forum: Design Module
    Assigned Moderators: N/A
    Posted by: [url=http://52.178.132.139/member.php?u=2795]HowlingWolf[/url]
    Original Content:
    The error on creating a pipe looks like a problem with the MDB configuration - check that the right cats/specs data is available
    The error on starting MDS is a missing item which may also point to a problem with the MDB configuration (a database missing perhaps?)
    The error on exit from PDMS looks like a missing folder (/%PDMSUSER%\des-tts-DESIGN ) but that is more probably a configuration problem as well because that name would normally be a FILE nor a FOLDER.
    I would suggest that you double check your set up, folder paths, environment variables, PMLLIB/PDMSUI settings against the recommended settings in the AVEVA manuals or in the supplied AVEVA batch files...
