Hello /*,
Has anyone used the lastest TEKLA to E3D plugin (3.1.17.6E3D).
Does it convert TEKLA structures directly to GENSECs and PANE?
How to you get the form to load? Does it have to be added to tool bar?
Thanks for your TIME!
Hello /*,
You need Tekla Interoperability both in Tekla, to create the export, and E3D to execute the import.
If you have configured your mapping file, it will create GENSEC.
Read the manuals from Tekla on how to loading it in E3D
Hi Henrk,
Thanks for you reply. I've edit my designAddins.xml and included a path to the TS-E3D folder but the addin not visible.
Do I need to create a new UIC file as well?
