In AVEVA Hull Design, when you start "Plane Part Generation", a drawing with sketch of all plate parts is generated, which is located in the "Hull planar part drawings" section.
If the name of the material quality uses more than three characters, the program incorrectly displays a line with the text description for welded flanges and clips in the planar part drawing. Example: Clip text line looks like [COLOR=#008000]"P A40300, TH = 12.0, QU = PC"[/COLOR].
In this case, the correct entry should look like:[COLOR=#006400]"POS = 1300, TH = 12.0, QU = PCA40"[/COLOR]
