Macros & Tools PrintPlot - Freeware
  • Replies 7 replies
  • Subscribers 14 subscribers
  • Views 50 views
PDMS Guru
PDMS Guru over 19 years ago
  • PDMS Guru
    Thanks goes to darrel:
    This utility is for batch printing plot files outside of PDMS. You must still have the Plotviewer application installed, but does not need PDMS installed. Written in VB6.
    Buginfo v1.0.2:
    Run-time error '68' - Device unavailable
    Fix: Delete printplt.ini or edit "Default_Dir="
    Run-time error '76' - Path not found
    PrintPlot
  • Mark Inverarity
    Mark Inverarity over 15 years ago
    Though i would add this tip to thread, since it is kinda relevant.
    If you create a MSDOS Batch file with the current line in it
    FOR %%A IN (%*.*) DO \\PDMS\AVEVA\pdms11.6\Plot\PlotViewer.exe /p %%A
    You will need to modify the path to suit your Plotviewer.exe location.
    Then make a shortcut to the batch file and and place it on your windows quicklaunch toolbar
    You can then drag and drop PDMS Plot files directly onto the shortcut icon.
    The /P switch launches plotviewer without displaying file, E.I. it will send the dropped .plt files directly to your current windows default printer. Make sure prior to use, that your desired print settings and printer is set the way you want it. :D
    Cheers
    Mark
  • Anthony
    Anthony over 14 years ago
    This link isn't working anymore. What is the program called, PrintPlot?
  • Mark C. Malazarte
    Mark C. Malazarte over 14 years ago
    198799PrintPlot..zip
  • Anthony
    Thank Pogi. I'll give it a shot...
  • nils boquin
    nils boquin over 14 years ago
    I have a shee with this name : /STRU/JACKET/XN-0001/01
    l use this command from the command-line : /STRU/JACKET/XN-0001/01 PLOT SHEE PRINT 'COLOR BW,MINL 0.1,NODIALOG'
    The problem is that l want print directly my shee without the print-dialog-window.
    How can l fix this problem?
  • Neil Dryden
    Neil Dryden over 14 years ago
    Use your search facility...
    I've commented on this more than once...
