Macros & Tools excel table to draft
  • Replies 37 replies
  • Subscribers 15 subscribers
  • Views 190 views
Tiberiu
Tiberiu over 12 years ago
Top Replies
  • Tiberiu
    Tiberiu over 12 years ago +2
    Hi all, I've made a little macro for transferring the selected area from an excel sheet as a table in draft and I would like to share it with the community. I use it mainly for BOMs. It generates…
  • Viet Anh Le
    Viet Anh Le over 3 years ago in reply to timothy +1
    Hi, Can you please reupload the code? I can't find it in this post any more. Thank you!
  • Tiberiu
    Hi all,
    It generates a
    • Vote Up +2 Vote Down
  • timothy
    timothy over 12 years ago
    I tried this out and just gotta say....NICE!!
    impressive VBA and PDML skills.
  • timothy
    tbmale
    fyi
    I did change two lines of code to make this work better for my needs. the first change was just a preference but I diffently would keep the second change.
    1st change, the line...
    fp.writeline ("NEW NOTE /" + fname)[/i]
    was changed to...
    fp.writeline ("NEW NOTE")[/i]
    just would rather name the note myself then have some long filename for the name.
    then I changed...
    buf = buf & "Origin Offset X " & x & " Y " & y & clrf[/i]
    to
    buf = buf & "Origin Offset X " & x & ".5" & " Y " & y & clrf[/i]
    this was so the text was slightly offseted the STRA and not right on the line.  Makes it look neater.
    Anyway, Awesome code, thanks allot!!!
  • Tiberiu
    Thanks
    Feel free to change anything :)
    One neat thing would be to align numbers to the right ... :D
  • Nein
    Nein over 12 years ago
    my problem is, that the macro destroy the variabel of the CHEIG....for the note the cheig is correct (in this case 4mm) but for the texp the cheig is replaced to cheig 0...what is the Problem?
  • Nein
    ah sorry i think i solved the problem...i defined the GLOBAL TH to PUBLIC TH...because with GLOBAL TH i had a failure and cannot run the macro...Thanks, NICE WORK!
  • Tiberiu
    Try to play with the line
     wlen(i) = wlen(i) * TH / 8
    modifying the width ratio (8) - a smaller figure means wider rows
  • Nein
    ok thanks i will try
  • francis dela cruz
    francis dela cruz over 12 years ago
    Hi,
    I just saw this thread and looks it will be very helpful. I'm not a programmer or have enough knowledge in PML. Could you give it a little more explanation on how to used this? thanks.
    [QUOTE=tbmale;68754]Hi all,
    It generates a
  • Tiberiu
    Where exactly do you have difficulties?
