Macros & Tools Add Volume and Clipping Manager
  • Replies 11 replies
  • Subscribers 15 subscribers
  • Views 293 views
Aurelio Hinampas
Aurelio Hinampas over 9 years ago
Top Replies
  • Aurelio Hinampas
    Aurelio Hinampas over 9 years ago +3
  • Aurelio Hinampas
    • Vote Up +3 Vote Down
  • Aurelio Hinampas
    Instructions for setting up all PDMS macros
    1.       Type in the command window: Q EVAR PDMSEXE
    It will give you the PDMS installation directory, navigate to the following directory. Example; for pdms12.1.sp2: C:\win32app\Aveva\pdms\pdms12.1.SP2 for pdms12.0:C:\AVEVA\Plant\PDMS12.0.SP6. Directory will vary depending on the version you are using.
    2.       Looked for the folder PMLLIB.
    3.       Create your own folder inside the PMLLIB example: myFolder and then Saved All the PDMS macro file inside the folder you’ve created.
    4.       Saved all the PDMS macros inside your folder in the PMLLIB.
    5.       Optional:
    Looked for the file name PML.index inside the PMLLIB directory and DELETE the PML.index file. Do not worry, it will be created again. Purpose is to rebuild the pml.index list so that the newly added pml macros will be included in the list.
    6.       Go to your PDMS command window and type: PML REHASH ALL to rebuild the pml.index list.
    CLIPADDVOL callcout command, Type in your PDMS command window:
    SHOW !!CLIPADDVOL
  • Benjamin Heredia
    Benjamin Heredia over 9 years ago
    Thank you my friend..
  • TONTHATQUANG
    TONTHATQUANG over 9 years ago
    very usefull
  • Miguel Lourenço
    Miguel Lourenço over 9 years ago
    Awesome work!
  • ian kirby
    ian kirby over 9 years ago
    Hi,
    Having error on mine, any help please.
    C:\AVEVA\Plant\PDMS12.1.SP4
    states:
    (2,779)   Method .LOCKOPTION(
  • Aurelio Hinampas
    It advisable that your folder name in the PMLLIB SHALL not have any spaces in between.
    To show the clipAddVol pml macro, type in your pdms command window: SHOW !!CLIPADDVOL
  • Cookie Cortes
    Cookie Cortes over 5 years ago
    Highly appreciated in 2020 bro. Many thanks!
  • Sachin Jadhav
    Sachin Jadhav over 3 years ago
    How to do in E3D please explain
    Corrado Galluzzi over 3 years ago
    In E3D you have a native tool --> VIEW Tab --> Clip Group
