Macros & Tools 3d text import in pdms
  • Replies 11 replies
  • Subscribers 15 subscribers
  • Views 100 views
THOMAS MUKIN
THOMAS MUKIN over 7 years ago
    Corrado Galluzzi over 7 years ago
     RE: PDMS Design: How to make Text on 3D model as Grid Text..
    HTH
  • THOMAS MUKIN
    How to import in 3d text in pdms.
    By,
    thomas mukin
  • 陈鹏
    陈鹏 over 5 years ago
    HTH
    Hello Mr Corrado,
           Can you please share the link or the contents to the link again? It seems that this link can not be opened, thank you!
    Corrado Galluzzi over 5 years ago
    Try with this:  http://www.plantcon.dk/uk/mfreedown.htm
  • Avtar Singh Hans
    Avtar Singh Hans over 5 years ago
    Hi,
    I tried to run Macro but E3D says FNF/DNF not found.
    Please help me.
    BR,
    Hans
    Could you please explain exactly the way you do it?
    Please consider that that macro has been originally developed for PDMS and it probably need some adjustment
  • Avtar Singh Hans
    Hi Corrado,
    Below is how I do it:
    a) Unzipped the directory from plantcon to desktop.
    b) Copied all attachment to C:\Program Files (x86)\AVEVA\Everything3D2.10\PMLLIB\design\forms
    c) In E3D,
       - typed PML REHASH ALL
       - SHOW !!BOGST
       - SHOW !!MLETTER
    It gives error message, F&M: Form BOGST not found.
    F&M: Form MLETTER not found
  • Venkata Rao Peta
    PML INDEX you have do before, which builds the pml index file.
    Check whether it is updated or not.
    Later you do
    PML REHASH ALL
  • Stephen Laniru
    Stephen Laniru over 5 years ago
    I did all that but it is not working with E3D
  • Nguyễn Hải Đăng
    Nguyễn Hải Đăng over 5 years ago
    hi sanmi[COLOR=#3e3e3e],
    As I know, you will need to provide admin permission to edit file in folder [/COLOR][COLOR=#333333]C:\Program Files (x86). This is the reason why E3D unnable to re-write your pml index file. There are 2 way to fix this:
    1. manually edit pml index file with Notepad++ or notepad (don't forget to run as admin)
    2. edit bat file to add pmllib eviroment variable to another folder (where you have full permission to edit file) and copy your macro to this folder.
    [/COLOR][COLOR=#333333]Then re-open E3D type pml index pml rehash all and show your form.[/COLOR]
