Macros & Tools total pipe length
  • Replies 12 replies
  • Subscribers 14 subscribers
  • Views 261 views
total pipe length
Pravin Parvekar
Pravin Parvekar over 5 years ago
  • Pravin Parvekar
    hi,
    i want to calculate the total pipe length,
    if at branch level i give a command q clle then it gives us the length at branch level,
    if the pipe has n number of branches then the macro should go on every branch get the length and add it then reflect the total length of the pipe,
    can any one help me with it
  • Venkata Rao Peta
     total cutlength of pipe(totalling bran clle)
  • Pravin Parvekar
    thanks deva for providing the link,
    i initially tried to find it before posting didn't found it
    hi @deva
    define function !!collectAllFor (!types is STRING, !expr is STRING, !item is DBREF) is ARRAY
    Called from line 18 of Macro C:\Users\PravinNamedeo.Parvek\Desktop\first.pmlfrm
       !branches = !!collectallfor(|BRAN|,||,!pipe)
    this is some error that i am getting can you please help
  • Venkata Rao Peta
    [COLOR=silver][SIZE=1]
    [/SIZE][/COLOR]hi you are trying to convert into a function?
    directly copy this macro and create a file .pmlfnc
    no need of arguments?
    there is no diff between function and macro
  • Pravin Parvekar
    var !pipes coll all pipe where matchwild(NAME of site,'*PIPE-JLE-ROS*') eq TRUE
    --!pipes = !!collectallfor(|PIPE|,||,!!ce)
    !output = array()
    do !pipe values !pipes
    !len = 0
    !branches = !!collectallfor(|BRAN|,||,!pipes)
    q var !branches
    return
    do !bran values !branches
    !len = !len + !bran.cllen
    enddo
    !output.append(!pipe.name & | Length: | & !len )
    enddo
    q var !output
    i want this as a report in excel
    [COLOR=#333333]q var !branches[/COLOR]
    [COLOR=#333333]return
    this is to be deleted a just doing trials on it [/COLOR]
  • Venkata Rao Peta
    .csv it will generate not .xls or .xlsx
    if you want excel file use grid function, don't know you are using E3D or PDMS.
    !output = array()
    !len = 0
    enddo
    enddo
    !file = object file(|%PDMSUSER%\length.csv|)
    !file.writefile(|OVERWRITE|,!output)
    !file.close()
    syscom 'start excel.exe $!file&'
  • Pravin Parvekar
    thanks for the help
    [COLOR=#333333]!pipes = !!collectallfor(|PIPE|,||,!!ce) is from pml2
    [/COLOR]which i am not used to
    so i converted that into pm1 format
    [COLOR=#333333]var !pipes coll all pipe where matchwild(NAME of site,'*PIPE-JLE-ROS*') eq TRUE
    [/COLOR]and then worked on it
    but got the result as needed
    thanks again for your help
    but can you write the same pml1 in pml2 with matchwild where to place and how to use
  • Venkata Rao Peta
    !pipes = !!COLLECTALLFOR('PIPE',|MATCHWILD(ATTRIB NAME OF SITE,'*PIPE-JLE-ROS*')|,!!CE)
    Q VAR !pipes
    !pipes = !!COLLECTALLFOR('PIPE',|MATCHWILD(ATTRIB NAME OF OWN OF OWN,'*PIPE-JLE-ROS*')|,!!CE)
    Q VAR !pipes
  • me_hungry
    me_hungry over 5 years ago
    @deva
    By the way MATCHWILD can be reduced to MATCH and !!CE to CE
    [COLOR=#333333]!!COLLECTALLFOR('PIPE',|MATCH(ATTRIB NAME OF SITE,'*PIPE-JLE-ROS*')|,CE)[/COLOR]
    :cupcake:
  • Venkata Rao Peta
    [QUOTE=me_hungry;115442]@deva
    :cupcake:
    Thank you me_hungry
