Macros & Tools Cut piece control
  • Replies 11 replies
  • Subscribers 14 subscribers
  • Views 111 views
Cut piece control
Sy Dinh
Sy Dinh over 4 years ago
  • Sy Dinh
    Hi all, I have a trouble in controlling cut pipe piece when upgrade the isodrawing to the next revision.
    When I issue the first revision of iso using Isodraft, the piece is numbering <1> to <5> sequently (for example). However, design change and we add one more weld in piece number <2> in order to split it into two single new pieces. Re-producing the next iso revision, the piece will re-number <1> <2> <3> <4> <5> <6>
    The piece <3> to <5> now become <4> to <6>.
    Any solution to keep unchangeable piece as original number (<3> to <5> in this case).
    And piece <2> will become <2> and <6> (the biggest number after change).
    Thank all!
  • Venkata Rao Peta
    Venkata Rao Peta over 4 years ago
    Control will not be there on this, user can customize only option file.
    If there are less sheets, modify in AUTOCAD as per your requirement.
  • Sy Dinh
    Thank Deva. Could you please advise in more detail that how user can customize option file for which section in this case?
    In conventional, our designers have to modify in AutoCAD environment which is time-consuming and human error might always occur. Therefore, I just brainstorm the innovative solution to control it more effectively.
  • Henrik Landström
    Henrik Landström over 4 years ago
    You should look into spooler module and use it to create the isometrics.
    An alternative to spooler:  Prefix in spool numbering
  • Sy Dinh
    Hi Sir, Yes. I can and I am using Spooler module to generate SPLDRG isometric drawing. I can manage the change of spool number, but pieces are different story. One spooler can include one or several cut pieces. And the piece number can only create after generating isometric completely. I honestly have no way to get that piece number in Design or Spooler Module. How can we control the piece number as my first question?
    Mr. Corrado. That topic is subjected to Spool prefix, not piece number control. I can query the piece number as per spool in SPOOLER Module by using SPLMTO object (CUTPIECES attribute). But it's totally different from piece numbering from ISODRAFT.
    Any idea sir?
    Do not stop just reading the topic title!!!
    My link was to a specific post of that thread where I am saying:
    "For those who are using SPOOL module, I would suggest to take a look at the Pipe Fabrication tool set within Piping Discipline in MODEL.
    That is a powerful, modern and up-to-date set of functionalities dedicated to pipe fabrication needs."
  • Sy Dinh
    Which version/fix are you using?
  • Sy Dinh
    It is ver12.1 sp4
