collect elements and delete exact duplicates
  • Hi Guys,
    I need some help by detecting and delete 1:1 duplicates in E3D Design.
    My suggestion is to collect the elements-> get the attributes for every element->sort these collection by the attributes->compare each "line" with previous line->delete elements with same "line"
    Example: Cyli under sube
    1. collect all cyli for sube
    2. get Attributes: height, diameter, position, orientation
    3. sort these elements by:
    3a:height
    3b:diameter
    3c:position
    3d:orientation
    ->now all double elements shout by sortet
    4. compare second element with first element: if attributes (height, diameter, position, orientation) are the same-> delete element, if not-> compare third with second element an so on...
    How can I realize that easily? With stacked arrays or with an table? How can I compare the attributes?
    Or is there an completly different way to get to my resault?
    This should be only the beginning, I would do this with other elements also.
    Thank you for help!
  • Maybe this can be a piece towards a solution
    !elementA =  /ApatrololB/MOTOR/Plate
    !elementB = /ApatrololA/MOTOR/Plate
    !attributes = !elementA.Attributes()
    do !attribute values !attributes
       if !elementA.$!attribute ne !elementB.$!attribute then
           $p not the same value for $!attribute
       endif
    enddo
