nozzle collection error
Hi everyone,
created a macro to get output of nozzle
VAR !NOZZ COLLECT ALL NOZZ WI (dbtype eq 'DESI')
--VAR !NOZZ COLLECT ALL NOZZ
VAR !PROJ PROJ ID
!outfile = object FILE (|c:\APPS\$!PROJ $C_NOZZ-ERR|)
!outfile.open(|OVERWRITE|)
!outfile.writerecord('SITE * ZONE * REF * TYPE * NAME * P1BORE * P1CONN * DUTY * CREF * CATREF * SPREF * DBNAME * DBFILE')
do !a from 1 to !NOZZ.SIZE()
$!NOZZ[$!A]
!SITE = NAME OF SITE
HANDLE ANY
!SITE = 'NULL'
ENDHANDLE
!ZONE = NAME OF ZONE
HANDLE ANY
!ZONE = 'NULL'
ENDHANDLE
!REF = REF
!TYPE = TYPE
!NAME = NAME
!P1BORE = P1BORE
HANDLE ANY
!P1BORE = !!error.text---------getting error on this line
ENDHANDLE
!P1CONN = P1CONN
HANDLE ANY
!P1CONN = !!error.text---------getting error on this line, as i would like to output the error code
ENDHANDLE
!DUTY = DUTY
--!SYSTEM_NO = ':SYSTEM_NO'
!CREF = CREF
!DBFILE = DBFILE
!DBNAME = DBNAME
!CATREF = NAME OF CATREF
HANDLE ANY
!CATREF = !!error.text
ENDHANDLE
!SPREF = NAME OF SPREF
HANDLE ANY
!SPREF = !!error.text
ENDHANDLE
--!outfile.writerecord(|$!SITE * $!ZONE * $!REF * $!TYPE * $!NAME * $!CATREF * $!SPREF * $!DBNAME * $!DBFILE|)
!outfile.writerecord(|$!SITE * $!ZONE * $!REF * $!TYPE * $!NAME * $!P1BORE * $!P1CONN * $!DUTY * $!CREF * $!CATREF * $!SPREF * $!DBNAME * $!DBFILE|)
ENDDO
!outfile.close()
$P ******** END OF REPORT ANB ********
any guidance
  • and yes in the same macro how can we take UDA
  • ...honestly, I would write this in PML 2.
    -- can keep this
    VAR !NOZZS COLLECT ALL NOZZ WI (dbtype eq 'DESI')
    do !nozzle values !nozzs
    -- !nozzle is a STRING
    -- converting to DBREFerence
    !nozz = !nozzle.dbref()
     !site = SITE of $!nozz
     handle any
         !site = 'NULL'
     endhandle
    -- zone same as site
     !ref = !nozzle
     -- now we'll ask all the info from the dbref object
     -- this is way faster as you don't actually need to CE the object
    !type = !nozz.type
    !name = !nozz.name
    !duty = !nozz.duty
    !systemNo = !nozz.:SYSTEM_NO
    !dbname = dbname of $!nozz
    -- this will be a reference number mind
    !cref = !nozz.cref
    -- this will be a name
    !crefname = !nozz.cref.name
    -- names
    !catref = !nozz.catref.name
    !spref = !nozz.spref.name
    --- sometimes these *ref.name error out. I've no idea why. the fix is:
    -- !cref = !nozz.cref
    -- !crefname = !cref.name
    -- Now, the bores; if you select the nozzle in the tree, and type q p1bore in the command line;
    -- the answer you will get is something like Ppbore 700mm
    -- so to get the data;
     !p1bore = !nozz.ppbore
    -- same experiment with p1conn, we get something like Ppconnect FGC
    !p1conn = !nozz.ppconnect
      --- SAVE TO FILE SAME AS YOU DID
    enddo
    There you go.
    Also, !!error.text() is a method as far as I remember, not an attribute, so to write it out you would need
    !variable = !!error.text(),
    not
    Hope I helped a little.. Note I didn't run this; so there are possible typos etc; please check.
    enddo
  • many thanks for looking at my query, i will run this & paste the output
    many thanks
