Not to be misunderstood I am not referring to the properties in the section "Selection Tree" but I refer to the property in the form Propriets that is opened using the command "View-> Control Bar->Proprietes" of Naviswork
The PDMS tab will not show up in the properties on items in the selection tree if there are no attributes for that item that you have selected on the selection tree. For example, if you didn't dump out attributes for the zone but you did for an equi then if you have the zone selected in the selection tree the PDMS tab will not be shown in the properties tab. As soon as you select the equi the PDMS tab will be there.
Again that is if you set the global options by being be sure you check the box that says search all attribute files, also make sure the attribute file and the rvm file are named the same. Then open the rvm file.
A simple request, you can change the settings of DbListing so that I pull out all the information in my subject (I am referring to all the attributes and UDA)?
Ok perfect thanks to all for the help.
I would like to leave one last comment: "Unfortunately, the data do not appear between the values of P1bore and P2bore on piping components."
This unfortunately does not allow me identificar andthe diameter of a component in Naviswork.
[QUOTE=Mr P.;78795]Ok perfect thanks to all for the help.
You can write a macro to extract what information you want to see. You just have to make sure it is outputted with the header that the dump attributes has. Just open your attribute file and see. We have done that here and it works great. We only extract certain information out on specific items.
Thats right, if U need to extract p1 bore or even tubi info just create analog of Dump Attribute and include needed att(with pml). Even, attribute of owne of owne, if your customer ask U.
I tried searching the forum but unfortunately I did not find the post that deals with this subject ... or the post that talks about how to change the function Dump Attribute
