Exporting Dump Attributes Macro file shared...
  • [LEFT][COLOR=#222222]Hi, do you have a macro to export dump att from E3D?[/COLOR]
    [COLOR=#222222]thanks[/COLOR]
    [COLOR=#222222][FONT=Verdana]Luco
    [/FONT][/COLOR][/LEFT]
  • [QUOTE=alinofeire;16373]Good Day!!!
    I have here macro file to export all dump attributes from PDMS to navis..
    if you want to change output folder just change line 27 of macro file
    Sharing is cool...
    tanx also for your help...
    PDMSWORLD rocks!!
    hehe...
    alinofeire
    See the first post!
  • what about just only one zone? which in the form i will change thank you.
  • Hi Russel, I know this post is a bit old. your macro is useful, but Have you ever thought about how to export pipe (TUBI) attributes?
    I tried do do that  my self but the result it's not encouraging.
    The problem is that the TUBE doesn't start any time as NEW TUBE 1 when the branch change.
    Please, could you have a look to help me?
    Thanx in advance.
    Below my modification
    $:debug$:
    $* modificato 12-04-2022
    $* Initialise Variables
    var !FILE |C:\Temp\DesReviewUda.txt|
    var !DILM |:=|
    var !SEPR |&end&|
    var !IGNORE |,NAME,OWNER,|
    var !AIGNORE |,unset,=0/0,nulref,|
    var !ODEPTH DDEPTH
    var !PDEPTH -99
    var !REFE REFE
    var !count 1
    $* Open file
    openfile /$!FILE write !FUNIT
    handle ANY
    openfile /$!FILE overwrite !FUNIT
    endhandle
    $* Write Header
    var !DATE clock date
    var !TIME clock time
    writefile $!FUNIT |CADC_Attributes_File v1.0 , start: NEW , end: END , name_end: $!DILM , sep: $!SEPR|
    writefile $!FUNIT |NEW Header Information|
    var !DPRT compose | Source$!DILM PDMS Data $!SEPR Date$!DILM $!DATE$n $!SEPR Time$!DILM $!TIME|
    writefile $!FUNIT |$!DPRT[1]|
    var !MDB MDB
    var !PROJECT PROJECT CODE
    var !NAME (FULLNAME)
    var !DPRT compose | Project$!DILM $!PROJECT $!SEPR MDB$!DILM $!MDB $!SEPR Element$!DILM $!NAME|
    writefile $!FUNIT |END|
    !list = 'SITE ZONE PIPE BRAN ELBOW TEE FLAN$
    OLET INST VALVE PCOMP GASK TUBI REDU$
    CAP COUP PLUG UNION ATTA FTUBE FILT$
    STRU FRMW SCTN'
    $* Get element
    Var !COLL collect all ($!list) with (name of zone eq'/PIPES')
    $* Loop through the list of elements
    do !INDX indices !COLL
    $!COLL[$!INDX]
    $* Hierarchy level
    var !DEPTH DDEPTH
    var !TAB $!DEPTH * 2 - $!ODEPTH * 2
    var !ITAB $!TAB + 2
    $* End(s)
    if($!DEPTH eq $!PDEPTH and $!PDEPTH neq -99) then
    var !DPRT compose space $!TAB |END|
    elseif ($!DEPTH lt $!PDEPTH) then
    do !INDXA from $!PDEPTH to $!DEPTH by -1
    var !DPRT compose space $!INDXA |END|
    enddo
    endif
    var !PDEPTH $!DEPTH
    $* Attributes of element  (this is new)
    var !ATTL delete
    IF (TYPE eq |TUBI|) THEN
    var !ATTL append |Itlength|
    var !ATTL append |Lbore|
    var !ATTL append |DTXR|
    ELSE
    var !ATTL attlist
    ENDIF
    -- initialise progress and interrupt system
    !progress = 0
    !progStep = 5 $* % progress report step
    $*!this.enableInterrupt()
    $*onerror golabel /interrupted
    $* Check it item is owned by a branch
    if(TYPE neq |WORL|) then
    if(TYPE of OWNER eq |BRAN| and NOT BADREF(SPREF)) then
    if (TYPE neq |TUBI|) then
    var !ATTL append |APOS|
    var !ATTL append |LPOS|
    var !ATTL append |CWEI OF CMPREF OF SPREF|
    var !ATTL append |AFTER(NAME OF PSPEC OF PIPE, '/')|
    $* var !ATTL append |:PNUM of spco of spref|
    $* var !ATTL append |:ENI_CODE of spco of spref|
    var !ATTL append |P1BOR|
    var !ATTL append |P2BOR|
    if(type eq |TEE|) or (type eq|OLET|)then
    var !ATTL append |P3BOR|
    endif
    endif
    endif
    endif
    $* Get name
    if (type eq |BRANCH|)then
    $!count 1
    endif
    if (TYPE eq |TUBI|)then
    var !NAME REPLACE (|$!NAME|,|ileave tube of |,||)
    if match(|$!NAME|,|of |)gt 0 then
    var !NAME AFTER(|$!NAME|,|of |)
    endif
    var !DPRT compose space $!TAB |NEW TUBE $!count of $!NAME|
    var !count $!count + 1
    else
    var !DPRT compose space $!TAB |NEW $!NAME|
    endif
    var !ASIZE (arraywidth(!ATTL)) + 3
    $* Loop through attribute array
    do !ATTR values !ATTL
    skip if(match(|$!IGNORE|,|,$!ATTR$n,|) gt 0)
    var !ATTRIB (ATTRIB $!ATTR)
    handle ANY
    var !ATTRIB $!ATTR
    $* replased text to have the best readible in Navis (this is new)
    endhandle
    var !ATTRIB (trim(|$!ATTRIB|))
    if(|$!ATTRIB| neq || and match(|$!AIGNORE|,|,$!ATTRIB$n,|) eq 0) then
    var !new REPLACE (|$!ATTR$n|,|Itlength|,|Lenght|)
    var !new REPLACE (|$!new$n|,|CWEI OF CMPREF OF SPREF|,|weight|)
    var !new REPLACE (|$!new$n|,|DTXR|,|Descr.|)
    var !new REPLACE (|$!new$n|,|P2BOR|,|Red. Size|)
    var !new REPLACE (|$!new$n|,|P3BOR|,|Branch Conn. Size|)
    var !new REPLACE (|$!new$n|,|AFTER(NAME OF PSPEC OF PIPE, '/')|,|Pipe Spec|)
    var !new REPLACE (|$!new$n|,|:ENI_CODE of spco of spref|,|ENI Code|)
    var !new REPLACE (|$!new$n|,|:PNUM of spco of spref|,|PUMA Code|)
    var !new REPLACE (|$!new$n|,|P1BOR|,|Main Size|)
    var !new REPLACE (|$!new$n|,|Lbore|,|Pipe Size|)
    if(|$!new$n| eq |Lenght|)then
    var !ATTRIB $!ATTRIB / 1000
    var !ATTRIB STRING ( $!ATTRIB, 'D2' )
    var !ATTRIB |$!ATTRIB Mt.|
    endif
    var !DPRT compose space $!ITAB |$!new$!DILM| width $!ASIZE R space 2 |$!ATTRIB|
    !size = !COLL.size()
    -- Update progress if required
    !percentDone = int( (!INDX * 100 ) / $!size )
    --$P index = $!indx, %done is $!percentDone, step $!progStep%
    if( !percentDone - !progress ge !progStep ) then
    !progress = !percentDone
    --$P $!progress%
    !!fmsys.setProgress( !progress )
    endif
    endif
    enddo
    enddo
    if($!DEPTH gt $!ODEPTH) then
    do !INDXA from $!DEPTH to $!ODEPTH by -1
    var !TAB $!INDXA * 2 - $!ODEPTH * 2
    enddo
    endif
    $!REFE
    closefile $!FUNIT
    $* Hide the from
    $* hide _CDXATTDUMP
    !!fmsys.setProgress( 0 )
    $P finish
    return $* >>>>>>>>>> End of Code DesignReview <<<<<<<<<<
  • Hey Walmic have you got any solution for this? if yes please share.
  • Dear Harender,
    I didn't have a look anymore, I'm involved in another tasks right-now. I'm planed to check it, next month. Regards
