I know there's a possibility to export from volume box - but export don't cut pipes... Is there possibility to get exactly cut box into rvm file ?
Or, maybe there is possibility to do it in Navisworks (we have Simulate 2012).
The problem with cuts in Navisworks is that we need to have whole (big) model, but we need to show customer only "clipbox" and everything what should be in Navisworks is only geometry from this "clipbox"... Then *.nwd file is smaller too ;)
Navisworks Simulate allows saved view points where you can clip and save, however if you publish while clipped, the nwd created is clipped as viewed in simulate, but the file size is the same and not any smaller.
