I'm having a problem with path editing. In path settings I have turned on 'show path in observer' (which the wording never shows completly) and 'enable graphical modification' (which also doesn't show the complete words) but the spline or waypoints do not appear in the graphic view or keyplan view. The locator handle appears if I have show waypoint grid turned on and I click on any of the waypoints.
Does anyone else have this problem? Is there a patch to fix this issue? Or could it be a graphic card problem?
The latest version is 12.2 (x64).
You can probably download it from Aveva website download area.
Or you can ask your local Aveva Office.
You could try installing that and see if your problem is solved.
Be aware that Review 12.2 does not use FlexLM but requires AVEVA License Server so you will have to install this as well as request a new license file from AVEVA to get 12.2 working
