Hello, i'm currently facing a problem with objects ladder during export from AVEVA E3D as RVM. all objects are at the correct position into Navisworks except the Ladders. There are at the point 0,0,0. i try to export them as DXF, but same phenomen into Navisworks. I'm currently using Fix 17 of E3D and Navisworks 2015 Manage. Is someone already faced this problem and solved it?
This has been reported to Aveva, but no word yet when it will be fixed. If you change your ladder to Detailed mode it will probably work as expected, it seems only ladders in Layout mode are affected.
