Model Review Software General export with colour
  • Replies 10 replies
  • Views 144 views
export with colour
Srikanta Chandrashekara
Srikanta Chandrashekara over 7 years ago
  • Srikanta Chandrashekara
    Dear all
    Please note below my command used export all equipment in the site with color green. after I need export some equipment under the same site with different colors. It is not working. All are exporting with the color green.
    I understood that , because all site equipment is changed to green color, later it is changing individual equipment under the same site.
    any suggestion , please
    EXPORT ALL SITE WITH PURP EQ 'EQUI' COLOUR 5
    EXPORT ALL EQUI WITH (PURP OF EQUI EQ 'HULL' OR NAME OF EQUI EQ 'HULL1') FOR CE COLOUR 49
    Regards
    I have many equipments under the same site, that is why I used ALL SITE.If I export individual equipment it is working.
  • Chad Shupe
    Chad Shupe over 7 years ago
    Try reordering and modify your criteria to
    EXPORT ALL EQUI WITH (NOT PURP OF EQUI EQ 'HULL' OR NOT NAME OF EQUI EQ 'HULL1') FOR CE COLOUR 5
    Because the first statement is ALL SITE WITH PURP EQ 'EQUI' is true for the equipment you are wanting different color I believe it will skip it just like in DRAW/DRAFT with RRULs.
    I too thinking the same, I do not know how to solve this.
    Is there any way to export the all the equipment with purpose unset. I tried, it is giving error. Please see below. I hope this can be done.
    EXPORT ALL EQUI WITH PURP EQ 'unset' COLOUR 49.
  • me_hungry
    me_hungry over 7 years ago
    Try this expression:
    [COLOR=#333333]EXPORT ALL EQUI WITH (unset(PURP)) FOR CE COLOUR 49[/COLOR]
  • Cary
    Cary over 7 years ago
    maybe you could also use Export Autocolour for example
       EXPORT AUTOCOLOUR RESET
       EXPORT AUTOCOLOUR  ON
       EXPORT AUTOCOLOUR ALL EQUI WITH (PURP OF EQUI EQ 'HULL' OR NAME OF EQUI EQ 'HULL1') COLOUR 49
       EXPORT AUTOCOLOUR ALL EQUI WITH PURP EQ '' COLOUR 49
       EXPORT AUTOCOLOUR ALL SITE WITH PURP EQ 'EQUI' COLOUR 5
       EXPORT ALL SITE
  • mEhul_patel
    mEhul_patel over 7 years ago
    Hello,
    For above problem give equipment with purpose and pipe with fluid code . And give rules 'PIPE\ALL WITH MATCHWILD (NAME, '*CWS*')\20' AND FOR EQUIPMENT 'PUMP\ALL EQUIPMENT WITH PURP EQ 'PUMP'\19 ( FOR EQUIPMENT AND STRUCTURE GIVE PURPOSE ON DESIGN MODULE)
  • Javad Ganjei
    Javad Ganjei over 7 years ago
    Hi, How can we set the transparency of the insulation in 50%? when we use utility export menu it comes out but when we use the command  "EXPORT /COMMON-JACKET COLOUR 15 repre insu On transl 50" it just shows as solid. Any idea?
    Thanks,
  • mEhul_patel
    [QUOTE=mg2794;107970]Hi, How can we set the transparency of the insulation in 50%? when we use utility export menu it comes out but when we use the command  "EXPORT /COMMON-JACKET COLOUR 15 repre insu On transl 50" it just shows as solid. Any idea?
    Thanks,
    When we export pdms to review file in Nevis works insulation show on solid.
    In our company we are make seperetly  review file (only insulation and obstruction) and after change transparency on Nevis file.
