PDMS 12 Bolt Diameter (BDIA)
  • Replies 5 replies
  • Subscribers 3 subscribers
  • Views 94 views
Sargon Akady
Sargon Akady over 6 years ago
  • Sargon Akady
    It's the nominal bore. Not the actual one.
  • Sargon Akady
    Thank you very much Corrado
  • Azmatulla Mirza Baig
    Azmatulla Mirza Baig over 6 years ago
    When there is a need to use a bolting catalogue with both Imperial and Metric projects, there is not always a direct conversion from one system to the other. For example, a 1/2 inch bolt may convert to a 12mm rather than a 13mm one.
    To overcome the problem, User-defined Nominal Bolting tables for diameter and length can be set up, as for the User-defined Nominal Bore table. The PURP attribute is set to BDIA for bolt diameters and BLEN for bolt lengths.
    For most users, the requirement is adding or removing a few bores. For this purpose, a macro of standard PDMS bores is provided (nominal_bore.mac), which enables a user to edit the values concerned and then input the User-defined Nominal Bore table into the catalogue.
  • Amrut Suthar
    Amrut Suthar over 4 years ago
    Hi dears
    Can you please see my below post and advise.
    https://www.avevaworldforum.com/showthread.php?19389-bolt-bore-unit/page2&highlight=Bdia
    Thanks
