PDMS 12 Dist
  • Replies 4 replies
  • Subscribers 2 subscribers
  • Views 29 views
Dist
SAMOEL JOINS
SAMOEL JOINS over 5 years ago
  • SAMOEL JOINS
    how can i use this command line in expression of report ?? (THIS COMMAND SHOW DISTANCE BETWEEN FACE OF FLANGE TO CENTER OF HEADER PIPE)
    Q CONS DIST PL TO PA OF HREF OF BRAN
  • Paulo Belesa
    Paulo Belesa over 5 years ago
    Can the command dist be used on a box or another primitive ?   so i can get the distance between BOX A  to Box B ?    or even better , the P1 of BOX A  to the P2 of BOX B ?
    Thanks in advance
  • Venkata Rao Peta
    PIN1 AT CE
    PIN2 AT CE
    var !dist cons dist PIN1 to PIN2
    q var !dist
    pin1 off
    pin2 off
  • Sam Anand Joseph
    Sam Anand Joseph over 3 years ago
    can this be used in report?
