PDMS 12 Importing dwg file to pdms
  • Replies 6 replies
  • Subscribers 3 subscribers
  • Views 93 views
PRAMOD CHARKARI
PRAMOD CHARKARI over 5 years ago
  • PRAMOD CHARKARI
    Hi experts
    is there any way to import dwg file into pdms 12 or some interface is required or need to convert any dwg file to any pdms file
    help
    thankx inadvance
    ashish
  • Azmatulla Mirza Baig
    Azmatulla Mirza Baig over 5 years ago
    this facility is available in E3D
  • Miska Merikukka
    Miska Merikukka over 5 years ago
    The  previous answer doesn't help a lot with PDMS12. I've manually imported DXFs with the importer (separate licence) but in that case the graphics should be exploded / bursted before the import. Without that they don't show correctly.
    I would also like to hear if there are some more straightforward ways to do this which wouldn't require manual work.
  • RAVI KUMAR
    RAVI KUMAR over 5 years ago
    PDMS/E3D can import/Export DXF file (3D) from AutoCAD.
    As i know import of external file is manual task only.
  • adak
    adak over 5 years ago
    in autocad --> export in .sat
    in pdms --> Equipement menu / MEI import and select .sat file
    Corrado Galluzzi over 5 years ago
    [QUOTE=adak;114866]in autocad --> export in .sat
    MEI officially supports STEP AP203 format only.
    You can also try with IGES and SAT, but something may go wrong...
