• Good day,
    - For Administrators who upgrade PDMS to 12.1SP5, please advise for:
    1. Did you face any problems after upgrading to 12.1Sp5 from 12.1sp4?
    2. What are the benefits did you get after upgrading to 12.1Sp5 from 12.1sp4?
    - For Administrators who are still using PDMS to 12.1SP4, what stops you from upgrading?
    - For me I just want to upgrade as PDMS 12.1Sp5 supports .Net 4.6
  • If you're using MDS application in version 12.1 SP4.46, 12.1 SP5 & above and your supports ancillaries naming does contains *.1, *.2, & so on... This will not work on this version since Aveva changed the naming format and remove those *.1, *.2 naming format.
    So far, only this issue I've encountered while upgrading to higher version.
  • [QUOTE=rhel;116694]If you're using MDS application in version 12.1 SP4.46, 12.1 SP5 & above and your supports ancillaries naming does contains *.1, *.2, & so on... This will not work on this version since Aveva changed the naming format and remove those *.1, *.2 naming format.
    thanks rhel for your feedbcak.
