Draw Vertex Editor / Direct DPPT selecting from PML / command line
Would be great if the vertex editor had an on/off toggle that sets whether the draw explorer follows / navigates to the relevant item that you select in the vertex list. So as you scroll through the vertex editor list, it also navigates in the draw explorer to the same item, if you have the on / off toggle set to on.
I notice that the vertex editor now has a pick option for directly picking the desired DPPT / projection line, which is great, but would be good if it also works in conjunction with above request and the draw explorer navigates to the picked item if the toggle is set to on.
Furthermore, it would be good if this picking option worked from the command line / PML, rather than only having the LDIM picking option.
For currently picking LDIM : id LDIM @
Additional option for directly picking DPPT : id DTTP @
