$S- $( BORE UNITS MM $) $( DISTANCE UNITS MM $) NEW SPECIFICATION /BPAMSEE VERSION 1151 MATREF =0 FLUREF =0 RATING 0.000 LINETYPE NULL BSPEC =0 TEXT 'BOLTING' HEADING TYPE NAME BDIA BTYP BSEL SHOP CATREF DETAIL MATXT CMPREF BLTREF DEFAULTS - - - BOLT DEF = BOLT */BBAMSEED 12.70 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEED BOLT */BBAMSEEE 15.88 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEE BOLT */BBAMSEEG 19.05 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEG BOLT */BBAMSEEI 22.23 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEI BOLT */BBAMSEEJ 25.40 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEJ BOLT */BBAMSEEK 28.58 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEK BOLT */BBAMSEEL 31.75 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEL BOLT */BBAMSEEM 34.93 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEM BOLT */BBAMSEEN 38.10 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEN BOLT */BBAMSEEO 41.28 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEO BOLT */BBAMSEEP 44.45 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEP BOLT */BBAMSEEQ 47.63 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEQ BOLT */BBAMSEER 50.80 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEER BOLT */BBAMSEES 57.15 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEES BOLT */BBAMSEEU 63.50 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEU BOLT */BBAMSEEW 69.85 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEW BOLT */BBAMSEEX 76.20 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEX BOLT */BBAMSEEY 79.38 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEY BOLT */BBAMSEEZ 88.90 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB16/A194.Gr7 =0 /BBAMSEEZ $S+
$S- $( BORE UNITS MM $) $( DISTANCE UNITS MM $) NEW SPECIFICATION /BPWM111 VERSION 1151 MATREF =0 FLUREF =0 RATING 0.000 LINETYPE NULL BSPEC =0 TEXT 'BOLTING' HEADING TYPE NAME BDIA BTYP BSEL SHOP CATREF DETAIL MATXT CMPREF BLTREF DEFAULTS - - - BOLT DEF = BOLT */BBWMDDDD 12.70 MACH DEF FALS /BOLT /SQUARE.HD.BOLT.+.HVY.HEX.NUT.ASME.B18.2.1/B18.2.2 /ASTM.A307.GrB/A563.GrA =0 /BBWMDDDD BOLT */BBWMSABD 12.70 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABD BOLT */BBWMSABE 15.88 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABE BOLT */BBWMJA0E 15.88 JACK DEF FALS /JACK /HEX.HEAD.SCREW.ASME.B1.1.UNC.CLASS.2A /ASTM.A193.GrB7 =0 /BBWMJA0E BOLT */BBWMSABG 19.05 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABG BOLT */BBWMSABI 22.23 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABI BOLT */BBWMSABJ 25.40 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABJ BOLT */BBWMSABK 28.58 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABK BOLT */BBWMSABL 31.75 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABL BOLT */BBWMSABM 34.93 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABM BOLT */BBWMSABN 38.10 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABN BOLT */BBWMSABO 41.28 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABO BOLT */BBWMSABP 44.45 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABP BOLT */BBWMSABQ 47.63 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABQ BOLT */BBWMSABR 50.80 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABR BOLT */BBWMSABS 57.15 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABS BOLT */BBWMSABU 63.50 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABU BOLT */BBWMSABW 69.85 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABW BOLT */BBWMSABX 76.20 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABX BOLT */BBWMSABY 79.38 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABY BOLT */BBWMSABZ 88.90 BOLT DEF FALS /BOLT /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2 /ASTM.A193.GrB7/A194.Gr2H =0 /BBWMSABZ $S+
