PDMS Guides Plate Nesting
  • Replies 5 replies
  • Views 17 views
Plate Nesting
Marco Cattini
Marco Cattini over 13 years ago
  • Marco Cattini
    Has anyone sucessfully found a program to nest plate from PDMS ? We need to maintain tracability of material and track changes within the plate order.
  • Luke Thum
    Luke Thum over 12 years ago
    Hey, that sounds like detective work.  Could you decribe your "nest plate". It should be interesting to see such things evolving.
    nerdy..
  • Venkata Rao Peta
    Venkata Rao Peta over 12 years ago
    I heard first time about this please give some brief introduction about this Plate Nesting.
    MarcoVz, you can find this functionality inside AVEVA Hull Detailed Design, part of the Aveva Marine Solutions Portfolio. [url=http://www.aveva.com/en/Products_and_Services/Product_Finder/AVEVA_Hull_Detailed.aspx]AVEVA | AVEVA Hull Detailed Design[/url]
    Plate nesting is usually a Shipbuilding activity...
    But I guess your company doesn't work in the Marine business.
    Hope this can help
  • kolade adejumo seun
    kolade adejumo seun over 12 years ago
    Some softwares can do nesting e.g tekla.
    The way it works is you specify the dimension of plates to be nested and the respective quanities.select the right plate thickness & it does the nesting for you.
    it is used to determine how how many smaller bits of plates( could be stiffeners, padeyes,node plates etc ) that a standard plate (say 3m by 12m) can accomodate. This helps construction guys to be able to quantify the total no of plates to purchase.
    I once heard that Pdms marine can do the same.
