PDMS Guides Pdms test project creation
  • Replies 8 replies
  • Views 11 views
Ramachandran
Ramachandran over 12 years ago
    If you read the manual carefully it says:
    Run the utility makemac.mac by typing: $m/%PDMSEXE%/makemac.mac
    If this doesn't wark you can try with $m/%PDMSEXE%\makemac.mac
  • Ramachandran
    Dear All,
    i just struggled with test project creation in PDMS 12.
    As per Aveva manual i have set environmental variables, then i tried to create
    test project by using make.bat from command menu and then entered test prject
    name with three alphabet and i have seen asterisk ( *) then tried to type
    makemac.mac to run the utility. But i got syntex error.
    Can anyone tell me what is the next step i have to carried out?
    Thanks in advance,
    Ram
  • Juan Manuel Gutierrez Valderrama
    Juan Manuel Gutierrez Valderrama over 12 years ago
    Hello.
    But in PDMS 12 you can make a project with the Project creation wizard.
  • Ramachandran
    Thanks to all for yours kind reply,
    I will try this steps and come back you later.
    Ram
  • James
    James over 12 years ago
    Nice post...........................................................,
  • Rufus Babatunde Lot
    Rufus Babatunde Lot over 11 years ago
    Hi ram2005j,
    I experienced similar problem:
    Please I need your guide to open PDMS 12 for use.
    I installed the PDMS 12, but I cannot start it, the way we start version 11.6.
    There is need to create project, I have tried to create project with the create project wizard, but it is still showing that the user’s Environment variables not set.
    Please help out on how to set the user’s Environment variables, or how to open the PDMS 12.
    If you have tutorial or manual  for this problem you can send it to me.
    Thanks in anticipation for your assistance.
    Have you read C:\AVEVA\Plant\PDMS12.0.SP6\Manuals\Docs\Administrator User Guide.pdf Chapter 6 Project Creation Wizard ?
    Project Wizard application should change/update your evars.bat file automatically.
    But depending on your PDMS installation, you may have to update it manually....
