PDMS Guides
Which attribute defines cable tray dimensions in .ATT file
Akshita
over 6 years ago
Akshita
over 6 years ago
Hi,
Which attibutes in .ATT file defines cabletray depth, width, length, load height, [LEFT][COLOR=#222222]load depth, and ladder height [/COLOR][/LEFT]?
Please do the needful.
Thanks,
Akshita
Venkata Rao Peta
over 6 years ago
Q FITLEN or Height will give length or height of cable tray.
Width, Depth will be on Catalogue parameters.Your components will be placed based on width of cable tray.
Load height and Load Depth are usually UDA'S.iam unable to find these Attributes as default.
Please go through existing catalogues in ACP to get some idea.
Akshita
over 6 years ago
Thanks Deva.
Will PARAM attribute can give me the width and depth?
I am confused as there are many combinations.
Example:
PARAM:= 600 64 1513 100 BOXI 758 21.5
PARAM:= 600 64 BOXI 100 21.5
PARAM:= 600 64 519 100 21.5 BOXI
[LEFT][COLOR=#222222]Can I get to know the significance of each word in this attribute?[/COLOR][/LEFT]
Venkata Rao Peta
over 6 years ago
These are called parameters which will be helpful for building geometries.
You should learn catalogue basics for understanding these concepts.
Akshita
over 6 years ago
Actually I am trying to read the ATT file and I want to get the crosssection of the cable tray. Is there any direct attribute to get the cross section as in like ABORE defines the width.
PRAMOD CHARKARI
over 5 years ago
Hi akshita
you can also try by going to
query[/b] in design toolbar select
properties [/b]
