$************************************************************************* !Remove = Array() Do !mcount = !Remove.size() id @ Handle (61,528) Golabel /Break EndHandle !Ref = ref If('$!mcount' eq '0') Then !Remove.append(!!ce) !mcount = !Remove.Size() Enha $!Remove[$!mcount] refre Else Do !x from 1 to !mcount If('$!ref' eq '$!Remove[$!x]')Then unenh $!Remove[$!x] refre $!Remove[$!x].Delete() golabel /Skip Endif Enddo EndIf !Remove.append(!!ce) !mcont = !Remove.Size() enha $!Remove[$!mcount] refre Label /skip !Remove = !Remove.Unique() Enddo Label /Break !Response = !!alert.Confirm('Are you sure you want to remove all highlighted items') If(!Response eq 'No') Then $PCancel return EndIf unenh all Do !Item from 1 To !Remove.size() $!Remove[$!Item] remove ce Enddo $****************************************************************************************
REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE REMOVE id @ REFRE
