PDMS Quick Tips & Customizations The MARK command
  • Replies 67 replies
  • Subscribers 3 subscribers
  • Views 102 views
The MARK command
Thomas Back
Thomas Back over 18 years ago
  • Thomas Back
    If you want to show some text on specific elements in design the MARK command can be used to easily accomplish this.
    An example of the syntax for the MARK command is:
    MARK WITH ( displaytext ) ALL ( selection ) WITH ( criteria ) FOR CE
    Where,
    displaytext   can be anything that evaluates to a text string. A few examples:
    NAME OF CATREF
    'Bore: ' + STRING(CPAR[1])
    selection is one or more element types that should be marked.
    criteria is the selection rule that applies.
    To remove all marks from the display, write UNMARK ALL
    /Thomas
  • Christopher Vitte
    Christopher Vitte over 18 years ago
    That is an excellent post TBack,   another good tip is the
    [COLOR="Red"]AID CLEAR ALL[/COLOR] command
    I had to use this alot in class, when extra aids are left on the screen after a user closes a window incorrectly, this will clean the axes, mirror plane, extention plane etc. off the screen,
    [COLOR="Lime"]EXTRA TIP[/COLOR]
    ((just make sure you don't have any contructs that you want to keep before you clear them))
  • Cheri Hook
    Cheri Hook over 17 years ago
    MARK WITH (NAME) ALL (EQUIP) works
    but MARK WITH (NAME) ALL (PIPE)  does not.
    any suggestions for marking PIPES WITH NAME ?
  • avwf_de_ding
    avwf_de_ding over 17 years ago
  • Javad Ganjei
    Javad Ganjei over 17 years ago
    Thanks alot De for your sharing;
    Thats very nice quick tool.
  • Javad Ganjei
  • avwf_de_ding
    Are u using PDMS11.6 SP4?
  • Javad Ganjei
    No.i use from PDMS 11.5 SP2
  • Cheri Hook
    We're trying to do some quick screen shots with the instruments tagged with the name and the elevation.
    MARK WITH (NAME) ALL (INST)  - this works
    MARK WITH (name and pos [3] ) ALL (INST)  - trying to mark the instrument with the Elevation.  ?? Do you know the correct  syntax to do confused_smile:
  • Neil Dryden
    Neil Dryden over 17 years ago
    Hi chook try this :-
    MARK With (STRING(POS[3]) + NAME) ALL INST
    Or put the required INST in a list and run
    MARK With (STRING(POS[3]) + NAME) CE
    Cheers
    Neil
