It skips the create component menu and shows the list of flanges available.
If only one option then that flange is created.
Works for any component type
NOTE: Autoconnect may not work and you may need to connect/position manually.
Hi may I know what is the command for piping to get the Pipe outside diameter with fire protection and also get pipe diameter but this time taking its original pipe diameter.
Ex. Pipe is 600 dia + fire protection of 50 will be 700 dia pipe with fire protection
[email]ian79kirby@yahoo.com[/email]
your posted your query at wrong place but still i will answer you.
Fire protection will be taken care by insulation in PDMS which you wil get in piping application create>>> components>>there you will get a option there you need to choose your insulation.
if your already routed your pipe just go to pipe ,branch and branch members and give ISPEC then go to graphics and set your representation
