PDMS Quick Tips & Customizations PDMS Commands
  • Replies 131 replies
  • Subscribers 2 subscribers
  • Views 370 views
PDMS Commands
Rafique Gazali
Rafique Gazali over 17 years ago
Top Replies
  • Rafique Gazali
    Rafique Gazali over 17 years ago +1
    aveva.dev-verintcommunity.com/.../197914PDMSCommands.pdf
  • ian kirby
    ian kirby over 13 years ago
    Thanks isurya!
  • Venkata Rao Peta
    Venkata Rao Peta over 13 years ago
    [QUOTE=ian79kirby@yahoo.com;58746]Hi may I know what is the command for piping to get the Pipe outside diameter with fire protection and also get pipe diameter but this time taking its original pipe diameter.
    Ex. Pipe is 600 dia + fire protection of 50 will be 700 dia pipe with fire protection
    Thanks
    q p1OD is the command for the outside dia of pipe eventhough on the component level stand on the component and put q param in the param od is defined
  • ian kirby
    tnx diva!
    Am i on the correct thread If I want to ask for commands?
  • Venkata Rao Peta
    Ya ur on the right place
  • Venkata Rao Peta
    Q BRIARE  Internal surfacearea of branch
    Q BREARE External surfacearea of branch
    Useful in Painting applications
  • ian kirby
    Thanks Deva.
    Question: Is there a shortcut command for copying members?
    What I mean is a short cut comand that i can type to the command line to copy member 'A 'with direction without using the Create/Copy on the Pull down menu
    Something like what we have on Draft wherein we can Copy like Ex. Repeat by y 50 or repeat by
  • Atish naresh parkar
    Atish naresh parkar over 13 years ago
    command : new FRMW copy prev by e 1000
    these command will copy the Frmw with the members under it towards East 1000
  • ian kirby
    Tnx atish will try it asap.
  • Darryl Helms
    Darryl Helms over 13 years ago
    I use this to find the face to face of a valve in Imperial units. If you want the metric value, remove the / 25.4 from the 1st line.
    1st - Make valve the CE
    2nd - In the command line type this in first and hit return:
               !!F2F = (2 * !!CE.CATREF.PARAM[2]) / 25.4
           then type this line in and hit return. (The value will be displayed in the command window)
               $P $!!F2F
    Hope this is of use to someone.
  • Raymond Metselaar
    Raymond Metselaar over 13 years ago
    !!F2F = fitlen / 25.4
    I wonder if above would work as well.
