PDMS Quick Tips & Customizations
temperature attribute
2 subscribers
Cary Kriston
over 11 years ago
Cary Kriston
over 11 years ago
hi all,
is it possible to set the pipe attribute temp to its all branch?. like if the temp of pipe is 70 means then the temperature of the branch should be 70.kindly advice
thanks
Shrivallabha Sharad Redij
over 11 years ago
Before creating any branches under the pipe if you set correct temperature on it then branches created will 'inherit' this temperature.
But I'd think this is not your question.
