PDMS Quick Tips & Customizations Pdms 12.1 sp4
  • Replies 8 replies
  • Subscribers 2 subscribers
  • Views 32 views
Pdms 12.1 sp4
karikalan
karikalan over 10 years ago
  • karikalan
    How to model stairs in pdms 12.1 sp4 version
  • Pedro Valadares
    Pedro Valadares over 10 years ago
    You have to use old ASL Modeller since the Access, Stairs & Ladders from 12.1.SP2 is disabled in SP4.
    The other option is to move to E3D.
  • Alan Gregory
    Alan Gregory over 10 years ago
    Is there a way of removing Access, Stairs and Ladders from the menu in 12.1 SP2?
    Possibly something similar to the method used to enable ASL Modeller only in reverse.
    randalf
  • Matts Nordman
    Matts Nordman over 10 years ago
    Randalf,
    the file that controls the Access, Stairs and Ladders application is called %pdmsui%/des/addins/access. Comment out all lines in that file and the menu entry will be greyed out making it impossible to start the application.
    M
  • Alan Gregory
    Hi Mno
    I thought that was the file you uncommented to get the ASL modeller (old method).
    I'm after hiding the new sparkly Access, Stairs and Ladders that only really works properly in E3D to stop the never ending designer questions about why they can't use the new version.
    Thanks
    Randalf
  • Matts Nordman
    Randalf,
    you are correct.. I have been messing with my computer before and disabled it somehow and now I can't remember what I did anymore.
    M
  • Alan Gregory
    No worries
    My guess would be that there is a file in %pdmsui%/des/addins/ that if you comment out the command lines will either stop the Access, stairs & ladders option from appearing on the menu or grey the option out.
    Randalf
  • Admin
    Admin over 10 years ago
    edit file access in C:\AVEVA\Plant\PDMS12.1.SP2\PDMSUI\des\addins\, edit like this below
    #  (c) Copyright  2004 to Current Year  AVEVA Solutions Limited
    #  File:            ACCESS
    #  Type:            Add-in Definition
    #  Module:          design
    #  Author:          Jamie Brunning
    #  Created:         Wed Jun 03 16:17:00 2004
    #  Description:     Add-in definition for ASL Modeller application
    directory:  ACCESS
    showOnMenu: TRUE
    object:     APPACCESS
    title:      ASL Modeller
    callback:   CALLAC IACCEAPP SCTN
    group:      1
    groupName:  Structures
    synonym:    CALLAC
    startUp:    $M "%PDMSUI%\DES\ACCESS\INIT"
    helpAlias:  DRMPCM
