PDMS Quick Tips & Customizations FCONN via c# Addin?
  • Replies 4 replies
  • Subscribers 3 subscribers
  • Views 126 views
FCONN via c# Addin?
Gelson Bieber
Gelson Bieber over 4 years ago
  • Gelson Bieber
    Is there a way to do a FCONN via C# Addin not using Command.CreateCommand? :D
  • me_hungry
    me_hungry over 4 years ago
    What is wrong with CreateCommand :indecisiveness:??
    using Aveva.Core.Utilities.CommandLine;[COLOR=#000088]
    [/COLOR][COLOR=#666600]...[/COLOR][COLOR=#000000]
    [/COLOR][COLOR=#660066]Command[/COLOR][COLOR=#666600].[/COLOR][COLOR=#660066]CreateCommand[/COLOR][COLOR=#666600]([/COLOR][COLOR=#008800]"FCONN"[/COLOR][COLOR=#666600]).[/COLOR][COLOR=#660066]Run[/COLOR][COLOR=#666600]();[/COLOR][COLOR=#000000]
    [/COLOR]
    or use PML function:
    [COLOR=#1C2837]Command.CreateCommand($"!!somefunction('{someParam}')").Run();[/COLOR]
  • Gelson Bieber
    Theres no specific issue with the CreateCommand, the problem is that every CreateCommand, the E3D must refresh its UI to type the command in the window, and for like 1000 loops, that makes the process much slower.
    I have tried a process using the Command.CreateCommand and not using it.
    Using the Command.CreateCommand it takes about 4 minutes.
    Without using it, its like 5 seconds.
    Thats why I dont want to use it.
  • Aslam Vohra
    Aslam Vohra over 1 year ago in reply to Gelson Bieber
    Did you get solution?
