Query specific parameter number with C#
I am trying to get specific parameter number for SCOM.
Say example I want to query parameter number 2 of SCOM.
I am using this syntax, but its not working.
arr[2] = ele.GetAsString(DbAttributeInstance.PARA, qual1);
I know qualifiers are for different purpose but as result is an array, i couldnt collect it as string.
Appreciate if somebody can help. Thanks
  • most probably the methods which you are trying to access is deprecated. However you can try following direct pml evaluations...
    ac.Command.CreateCommand("!X = param 1").run();
    and depending on you !x datatype you can use any one of the following method,
    ac.Command getCommand = ac.Command.CreateCommand("");
    // Converting to Upper Case is necessory
    string varString    = getCommand.GetPMLVariableString("x".ToUpper());
    bool varBool        = getCommand.GetPMLVariableBoolean("x".ToUpper());
    double varReal      = getCommand.GetPMLVariableReal("x".ToUpper());
